Hi All,*A little background. Car was diagnosed, cleared, and rediagnosed with P0303 cylinder 3 misfire several times. I swapped out coil pack 1-2 with 3-4. Same problem. Changed spark plugs. Runs beautifully for a couple thousand miles, until...*So a couple days ago I get the same P0303 cylinder 3 misfire.*What could be the cause? Plug wires? Something is causing the plug to foul maybe? Edit: No plug wire for cylinder 3What are the next logical diagnostic steps?*Thanks for your help,*-V
