Hi All,
I've been chasing a misfire on Cylinder 3 of a 2001 IS300. It's constant and entirely obvious.
Backstory:
I purchased the car from somebody who had broken the ignition casting and the car was stranded in his car port. He had disconnected the wires which sense the physical key presence (and make it beep) and was pressing those against the key and against the metal box of the RFID module (sorry, I forget the proper name of that box), misunderstanding how the security system worked. I had the car towed to my place, replaced the ignition switch, fired it up, sprayed down the engine at a car wash to clean off the oil from old oil leaks, let it sit a day or two, then drove it to emissions testing. It drove just fine to the emissions testing facility, passed without any problem, then as I was getting on the highway to go home, began missing on cylinders 2 and 3 and had the random misfire code.
So far I've:
Thanks in advance for any help!!
Backstory:
So far I've:
- Replaced one coil pack with OEM Denso and replaced plug wires and plugs - only cylinder 3 missing after this
- Swapped coil packs - no change
- Checked compression: clearly worse on cylinder 3 than the others, but not enough to be missing 100% of the time
6 - 175
5 - 180
4 - 180
3 -155
2 - 185
1 - 180
- Replaced spark plug wires again after previous replacements were visibly arching in the dark - new wires not visibly arching and cylinder 3 still misfiring
- Removed fuel rail, manually cleaned and flushed injectors, swapped injectors 1 and 3 - no change
- Replaced spark plugs one more time with OEM Densos - no change
- Purchased techstream cable (https://smile.amazon.com/dp/B0977HJB42) and tried 3 different versions of techstream - when I run "Health Check" every version crashes when it gets to ECU 2 of 9.
