So i got the cxracing kit, ill be installing this weekend, only concern now is the standalone/ecu, whats recommended nowadays? Local shop said megasquirt but theyre going downhill and dont want to risk it,
So bottom line, which tuner do you recommend? Thanks
My best advice is to choose who is going to be doing the tuning first.
Basically all the systems on the market are capable of working well. The overall goodness factor of your setup will come down to how well it was integrated into your car and tuned; NOT how good the ECU was to begin with.
If you have an ECU that your tuner is unfamiliar with - either you'll be paying him good money to learn how to use your ECU, or his result will not be as good as if you used an ECU he was already familiar with.
