OR..... How to cut a big hole in a possibly one-off rare as hell, Original A-51 vented CF hood,......freak out a bit afterwards, & then make it work and look sweet in the end...
FWIW..MANY of these projects i am now posting on started well over a year ago...it took me a long time to do them cause i cant work on the things as much as i want,... So the time line is quite condensed in these posts ... the actual work involved took FAR less time than working out the concept, methods, materials, & and the preparation..not to mention my undecisive procrastinatin' ass...
_______________________
I've been trying to figure out how to more agressively vent my "AirBox" thru my hood for a while now, i looked at all kinds of different vents & what not ... eventually deciding, I would try a NACA duct to help draw air down & in......
I found these acrylic ducts on line & bought a few, eventually I started chopping at them to modify them to use as a more proper NACA duct, in the hood.
after chopping them back & grinding them down with a belt sander... here are the 3 stages to a nearly finished duct.
Working out the CF 'Floor' and mesh...
... Using the ducts i worked out where the duct should go & what i had to do to make it fit.... i found the spot, marked an outline for the vent & free drew the inner line for the hole.. the tape lines mark the outside of the " Air box" space under the hood...
I cut the hole small & used a dremel & drum sander to shape the hole in the CF and i used the duct many times to keep checking the shape & keep things even & tight.
not bad for a hack...
So with the external hole thru the hood cleanly cut..:jawDrop: . i finished the mesh & shape of the CF duct floor duct.
Test fitting as it will be mounted...
the duct mesh secured & after a light coat of paint...its ready to install, epoxy works great...
i dont think it wil lbe falling off any time soon...
after epoxying it to the under side of the hood... i started filling in the gap to clean it up...
After sanding & a little paint...........I needed a bit more filler.....
After sanding the filler smooth & shooting the final coat of paint....
I am actually pretty amazed how nice it turned out & I cant wait to mount this hood FINALLY!!!!!
