21 - 35 of 35 Posts
Okay, lets look at control issues. Do you have a spare boomslang harness and emanage you could brow from someone? You could try briefly to unplug the boomslang and run for a sec on the factory ECU only. If it fires. Then the boomslang may have gone bad or the emange. I have had a boomslang harness take a krap before.
2001 Lexus is300 (turbonetics kit)
Discussion Starter · #22 ·
No.
disconnect the whole thing from which part exactly?
Discussion Starter · #25 ·
Not the harness, disconnected it and same thing just cranks doesn’t turn over
Discussion Starter · #28 ·
Any specifics on where to start, and is there a data/chart that I can see what specification everything should be at?
Discussion Starter · #34 ·
Is there any way the timing is off causing it to not start?
21 - 35 of 35 Posts
