1 - 13 of 13 Posts
I recently had a wierd problem with my car...this could happen to anyone. I noticed that my drive belt is not spinning in sync with my engine while reving.
***This is not caused from my accident***
This caused MANY troubles such as:
1. Alternater not charging (battery light turns on)
2. Lost of power steering
3. All sorts of neat troubles...car died on me out of no where
At first i thought it was the alternator not charging...checked all the fuses....everything OK. Checked wires from ECU to alternator-OK
Tried a different battery-no go, still not charging
Checked all grounds-no go
Then the least expected, i was reving my car trying to make the alternator charge then i notice the belt problem.
I took off the drive belt to see that the crank pulley is free spinning, the rubber around the crank pulley broke. I actually can pry the WHOLE pulley out. Here's a pic:
[/URL][/IMG]
Now i need my crank pulley replaced and its going to be a bitch trying to remove the crank bolt.
These are one of the wierd problems for the IS. Otherwise its a perfect car!
Interesting...
How many miles did your car have?
Glad you figured it out.
haha wow. Goodluck pal.
I guess i got bad luck. Mine is a 2001 IS300 with 64,000km. DAMMMMMMMMMM
Have you heard of this happening to other people?
Are you essentially saying the part of the pulley that comes in contact with the belt completely separated from the inner portion?!?!?! :confused:
yes, this is "common". or as common as "common" problems come on the IS300. I've seen this happen on 3 cars so far.
Discussion Starter #7
I got the crank pulley replaced and everything is good now. One of the first symptoms is when you start your car you get no power steering. OR when your driving the battery is not charging.
Damn, this problem plagues all the 2JZ's.. This problem is REALLY common for the Supras 2JZ-GTE, I guess it also occurs on the 2JZ-GE as well..
Is this for all 2JZ's? Or mostly for 2JZ's that have been boosted beyond belief.
Discussion Starter #10
Mine is a stock 01 with aftermarket muffler.
I needed my crank pulley replaced too... the guys at Bullock City noticed some wiggle room when they were replacing my timing belt (I was at 196K). They didn't charge me labour, but that part cost me 400+ :(
Yeah, the part was very expensive. They didnt charge you labour becasue when changing the timing belt, the crank pulley needs to come off...thats when they noticed the damaged pulley.
yup, lucky me, hehe :(
1 - 13 of 13 Posts
