1 - 2 of 2 Posts
the coils are a waste spark type if i am correct. therefore they would all fire anywayz. you may have a shorted wire that is arcing, and not getting spark to the plug. electricity takes the path of least resistance, which would be an arc, rather than a gapped plug. good luck. and are you having a no start issue due to oil, if you are, correct it quick, and dont crank until your sure that you will have pressure
1 - 2 of 2 Posts
