Ok, some of you might call me crazy...but I am so here goes. I want to convert my AC lines to AN fittings. Reason being that I need the lines in the front to be flexible to be able to clear my intercooler. I already bent the hell out of the stock lines and I'm afraid if I bend them anymore they are just gonna crack in half.
I know standard SS lines with rubber inner hoses will prob seep out the refigerant over time since those hoses are a bit porous. But the Teflon lined SS lines should be ok. I mean they use that stuff to flow nitrous and for brake lines which are about 1000psi or more. Anyways, my question is if the AN fitting can hold that kind of pressure without leaking.
