SophieSleeps said:
I'm running open loop with an e-manage.
WTF are you talking about?
wait
lemme ask you a second question.
-De
:lol:
I was talking about how any piggyback (emanage included) works.
It basically allows you to "reprogram" the ecu's basemap to achieve whatever a/f you would like with whatever size injector (there are limitations in injector choice) when the car is in open loop. This is achieved by having the piggyback intercept the maf input.
The unit contains a 3d table with 2 independant variables (rpm, maf voltage) and one dependant variable (maf OUTput to ecu). Many piggybacks offer supplementary enrichment (meaning adding x millivolts to the maf output to ecu) by throttle position, or rate of change, or what have you.
Now, when the car is in closed-loop (idling, coasting, low-load accelleration) the ecu will NOT go strictly by this voltage that you give it. It will use information taken from the first o2 sensor to richen/lean out the a/f as necessary in an attempt to achieve a 14.7:1(stoic) a/f ratio. Even if you tell the car you want it to idle at 12:1, it will idle at 14.7:1 after running for a few minutes. This is hardly a problem, though, as you don't need to be running a 12:1 a/f ratio at idle, or under gentle acceleration.
"Limp" mode- If you try to get the car to run TOO rich under closed-loop conditions (primarily under vacuum, idle, coasting), it will not be able to correct (lean out) the a/f enough to achieve 14.7:1 under closed loop, and it will flip out, thinking something is wrong, going into the infamous "limp mode" This is something that your tuner should easily be able to avoid.
There are more secrets to tuning using a piggyback ecu, and I will tell you this- the car does not HAVE to run 14.7:1 under closed loop operation. In fact, I have been working closely with some associates such that I will soon have programmable closed-loop a/f using the stock ECU. Once r&d is finished for that, you too will be able to do it also. Not that it's THAT important to be able to do it, but it is extra security when running f/i. Howdya like them apples?
The best part about all of this? You maintain all of the stock functions of the ECU... trac, CELs, knock detection, automatic timing retard in the event of knock, closed-loop operation... Basically the stock ecu still does all of the work for you, you merely manipulate what data it sees in order to control it (kinda like college kids and the liberal media :lol: )
-C
