1 - 20 of 23 Posts
i have a set of tein ss and it's not good on my back because i feel the road a little too much. so has anyone got a comfortable set of coilovers...i know of tein flex (not sure about) and there is tein cs. i want something that rides like stock or better. any suggestions on other coilovers i can look into?
- my HKS are comfortable... I heard the ZEALS are great too
lilaznboi said:
um...c'mon guys...this dude wants something close to stock...flex, hks, and zeal aren't even close to stock...even my H&R/Koni's aren't...
hks and non pillow mount coilovers no, but ZEAL and others are close to stock......
uz trippin....
hks is the only one so far that i have not felt good in.
David
i'm deciding between flex and cs and i can't afford the zeals. any experiences with tein cs? how is the ride with the tein flex...do u feel the bumps in the ground? is it less bouncy than tein ss? prices or someone i can contact about pricing? thanks in advance.
uz trippin....
David
- I must be on crack or my ass just has a lot of cushion
- or maybe beacuse I have not rode on anything else, so there is nothing for me to compare to... but mine feels good....
Some more info
From this thread http://www.is300.net/modules.php?name=Forums&file=viewtopic&t=13350770&highlight=tein+coil
CS may be too soft(?)
Flex is 'just right' (?)
According to Inochi3:
i believe the tein cs have 8/6 spring rates which are probably the softest there is for coilovers, i would get the tein flex if that was an option, i believe they have 10/8 spring rates, someone correct me if i'm wrong
http://www.is300.net/modules.php?name=Forums&file=viewtopic&t=13350730&highlight=tein+coil
The softer the rate, the closer to stock
Also, for the Flex the issue of rust:
http://www.is300.net/modules.php?name=Forums&file=viewtopic&t=13341622&highlight=tein+coil
But still lots of ppl with the Flex:
http://www.is300.net/modules.php?name=Forums&file=viewtopic&t=13341413&highlight=tein+coil
Noise issue:
http://www.is300.net/modules.php?name=Forums&file=viewtopic&t=13342531&highlight=tein+coil
if you are set on coilocvers don't forget apexi WS these are supposed to be pretty damn soft, a member got rid of them cause they were too soft and went for the N1 so that sounds like they are pretty soft
1 - 20 of 23 Posts
