Well, after less than 20,000 miles, I need to replace my clutch... Iv'e searched IS300.net and the internet. The best that I can find is an ACT clutch. The application chart show a TS3-HDMM (heavy duty pressure plate with a modified street disc). ACT's web site says, in theory, that you can upgrade the components. They say that you can get a TS3-XTSS (extreme duty pressure plate with a performance organic street pressure plate. Has anybody out there been able to order the later?
The motor used in the IS appears to be the same one used in the non-turbo MKIII Supra, the non-turbo MKIV Supra, and the ES300. I am pretty sure the Supras had clutches; not so for the ES. The tranny may not be shared amoung all the cars (IS included). This may be another source.
