Discussion Starter · #2 ·
Hello out there, i have had a lot of people view my question, but no one has made any comments I would love the input please.
Even if you can tell what type you have or what you would recommend
thanks i will check that out
I am looking for an affordable aftermarket clutch somehting around 500-900 for both flywheel and cluth.
Also my dealer said they had to replace the flywheel when ever they replace the clutch is that a recommendation or really true.
Penetration Specialist
not necessary unless it is really worn down. Check RPS out. They make nice high quality aftermarket clutches/pressure plates.
Make sure they replace the pressure plate bolts(if they remove it) as they are one time use. A friend of mine lost his right leg just a couple inches below the knee because he reused the bolts and he didn't have a scadder shield when his tranny blew. Also replace the pilot bearings as well as the throwout bearing.
