No, I have been wanting to, just dont have the equipment/tools for this yet. Is there an inexpensive smoke test setup that you would recommend?Have you smoke tested it?
I replaced mine about 4 years ago, but they are cheap, might get another....And gas cap
My buddy bought this one:No, I have been wanting to, just dont have the equipment/tools for this yet. Is there an inexpensive smoke test setup that you would recommend?
If you have a compressor. You can make one with some pipe and a cigarette. But it is a pain to use. Just buy one or ask a shop. Some auto parts stores have them to rent.No, I have been wanting to, just dont have the equipment/tools for this yet. Is there an inexpensive smoke test setup that you would recommend?
Same as a regular smoke tester. The pipe holds a lit smoke and then you force air through the smoke backward basicly. Then out into the system. Sorry I made one a very very long time ago. When Machines where real costly.Just out of interest how do you work them? Blow smoke into the engine bay and look for air movement? Or fill the intake with smoke and look for smoke coming out (im guessing you dont run the engine on this method?)?
Very common for the gas tank vapor vent valve to crack and cause this code.
You are referring to this part, yes?Very common for the gas tank vapor vent valve to crack and cause this code.
Yes it’s on top of the tank. Some people do cut the sheet metal under the seats as seen on YouTube.... that’s ratchet. Plus you better measure twice or you’ll be needing another tank. Correct procedure is to drop the tank. I noticed the strong gas smell even though the code was set only a couple of times. If you do drop the tank there’s another valve and gasket you should replace while you’re there.This is on TOP on the gas tank, yes? would require dropping the tank or removing the rear seats and cutting the sheet metal to access?
How would I be able to see this leak with a smoke test?
