So I got the chase bays power steering reservoir and I want to mount it to the strut bolt but it leaves very little space between the reservoir and stock intake manifold. Is that okay? or should there be more clearance?
MSM 2005 Lexus IS300 5AT
Yea that's what I was thinking, thank you for the reply! Know I know I'm doing the right thing mounting it closer to the pump, just got back from getting the fittings and hose I'll need to make a shorter feed line.
Pardon the noob question, how does the distance from pump to reservoir make a difference if the whole system is pressurized anyways (with the pump pulling from the reservoir)?
Discussion Starter #7
I was going to mount it closer to where the stock reservoir was just because there wasnt enuogh clearance where I had it but ended up mounting it by the brake booster, I don't think the distance makes a difference.
