Hi,
I have got my IS recently and am trying out all the cool options. One however has not be working as per the manual... the changing of the auto door lock and unlock functions. Basically I want to set it up so that all doors lock when I shit the gear out of P and unlock when I shift it into P. I tried the following steps (from the manual - Before driving section) but to no avail:
Has anyone tried this and been successful?To switch between setting and canceling, follow the procedure below:
Close all the doors and switch the engine switch to IG-ON
mode. (Perform the step 2 within 10 seconds.)
Shift the shift lever to P or N, and press and hold the driver's door
lock switch ( or ) for 5 seconds.
The shift lever and switch positions corresponding to the desired function
to be set or canceled are shown as follows.
