hello im currently working on my 2003 is300 and im having trouble with the throttle position sensor. upon closer inspection i see the actual plastic pieces of the connector are coming off and falling apart. ive been looking for a replacement i could soder in. the only one ive found is one for the gs but since they share the same engine could i use that on my is300?
Musical instrument Font Gadget Screenshot Musical instrument accessory
2002 is300
Should work the gs and is engine are pretty much identical. Another option would be a 1uz connector as I think they share the same style throttle body just different size from the is.
hello im currently working on my 2003 is300 and im having trouble with the throttle position sensor. upon closer inspection i see the actual plastic pieces of the connector are coming off and falling apart. ive been looking for a replacement i could soder in. the only one ive found is one for the gs but since they share the same engine could i use that on my is300? View attachment 141657
It is call the Accelerator Pedal Position Sensor or APP. Just so you know.
