Try turning the steering wheel. It is most likely locked in a position which will not let you turn the key. Turn the wheel in the only direction it will turn. It will take more force than normal, but once you turn a little bit, hold it there and then try the key.
I had this happen to me at that drag strip.
Go to Lexus, there is a defect in the ignition system, they should replace it free of cost...
