2001 E-Shift IS300 with around 115,000 miles.
Car has been sitting for about 10 months outside and I wanted to ask what should I check and/or replace before being driven. I already have a list of a couple things I will be doing:
  • Oil Change
  • Transmission Fluid Drain
  • Differential Fluid Drain
  • Coolant Flush
  • Bleed Brakes
  • Clean Fuel System (Tank, Injectors, Lines, Rails, Filter)
  • Clean MAF Sensor
  • Clean Intake/Throttle Body
  • Replace Air Filter
  • Power Steering Fluid Flush
  • Vacuum & Refill AC
  • Check Battery
  • Wheel Balance & Alignment
Anything else that should be done or checked?
Thanks in advance.
I would check the wheel bearings. Sometimes they flatten from having the weight of the car in one position for a long time.
