Not sure if this has been discussed before and the problem might be something stupid simple. But recently my is300 has been terrible to drive on the highway or most speeds over 60 mph.
The car likes to "sway" back and forth in my lane and feels rather unstable when driving at highway speeds. It feels like the car is off-balance in a way, such as the car would sway to the let side of the lane and will take a couple small movements of the steering wheel to be back on track.
I have BC coilovers with no preload rear an .25" preload set up front, shortened OEM spindles and Figs highsteer knuckles. Is this just a cause of the steering knuckles or am i looking at a deeper problem (inner tie rods, rack bushings, etc)? I never noticed this issue prior to the knuckles but I am doubtful it is the sole cause of my problem. Thank you!
Ball joints are new and came with the knuckles, I have also replaced the LCA #1 and #2 arms, FUCA, new outter tie rods, etc. So only thing I havnt touched is the inners and rack bushings
so sounds like those bushings are new... you can check for inner rod play just jack the front and check it. maybe your alignment got out of wack after hitting something or a pot hole. replacing the steering rack bushing def cleans up the slop. gl hf
when it is horrible you did not follow the rule and regulation for driving a car the main factor of horrible while drives a car is over-speed. Mostly the people lost their lives for over-speed purpose careless driving puts innocent people's lives at risk.
I have stock springs and some "Tenkis" or what ever, I don't know anything about the suspension on mine. Except, its not lowered (stock height minus like half a inch, I like being able to not slow down over speed bumps), it's nice and has new control and tie rods.
It's stable to 115 (highest I've gotten so far) and has shot bushings in front, and shot diff bushings. I don't know if them being cracked = shot? Anyways -- always make sure to put grease in the top and lower 2 tie rod and ball joints.
Your tires also have a speed rating. May want to check on that.
Related Threads
Lexus IS Forum
5.5M posts
129.7K members
Since 2000
