Where is this located on our cars? And im assuming its not removed for turbo'd cars?
The crankshaft position sensor is located infront of the water pump, there is a connector bracket holding the sensor there.
The alternator has to be remove to access the crankshaft position sensor connector, then remove bolt holding the connector bracket to the water pump, the remove the sensor.
there is a second camshaft postition sensor located in the back right of the motor as you are looking at it. Its underneath the tow hook. You may have to move some lines to see it but it is there.
Best I could find. You have to use your imagination.
Crankshaft
Crankshaft position on vehicle
Camshaft
Camshaft position on vehicle
Digger08
Reactions: jmooney5115
is this the location of the crankshaft position sensor on a 2008 lexus is 250 2.5L AWD
2002 Lexus IS300
LOL! While the above post by @Pnut00 is hilarious, I figured I cut you some slack and give you this handy picture I found on google. For future reference, your car is a 2nd Gen. IS that uses the Toyota GR engine.
136960
