1 - 9 of 9 Posts
is there a way to by pass the fan controller and have the fans running all the time? i saw this but i cant seem to do it is on a 2jz also
MKIV.COM
also is there a way to turn off or bypass the traction control system???
please help out a newbie :p
What's the reasoning to bypass the fan controller?
to keep the engine as cool as possible? thats always a good thing i think. im a newb so yeah i think its a good thing......
Not really a good idea...
if you say so, you guys know way more than i do. thanks for answering my question
I have an OE looking switch to bypass the fan, using the ECT circuit also. Off= normal operation. On= fan on. Why I did this was to "charge cool" the coolant while waiting in line to do another run at an Autox. Start run with hot coolant and thermostat fully open, not good. Start run with cool coolant and partially closed thermostat, better IMO.
To have it always on is not good, you want the car to be at its operating temp, and I'm not sure if the alternator can keep up with the fan load.
I'd post a pic, but photobucket is down right now.
^^^ That I will have to say is a GREAT idea.
Thanks. My friends thought the same, so two peeps here are rocking the same setup, and I need to meet up with 2TGEU to knock out his (and did it already to his 86 corolla along with the elec. fan conversion, man I like his setup).
We gotta meet up sometime, I can show you how to do it, or do it for you (though you know the harness and wire lay out better than I do), and you can look over the Tc. Haha, that Tc has been a test car lately, already has two "firsts" done to it, whats another one? haha.
1 - 9 of 9 Posts
