1 - 18 of 18 Posts
Hello I am fairly new to the forums and I was wondering before I do any type of crazy turbo builds if I should build my head first.
To start off I have no idea what kind of gte pistons/ rods etc I need to buy and where to buy it from. I am also kinda of new to building a 2jz ge as well , I just need some guidance on where to start as far as engine components
Doing the head depends on the shape of the engine. Also depends on the power range you are looking for. I would do a lot of reading here before asking.
I don’t see any stickies , as for the engine is been well taken care of has 131k miles on it , my power goals are 300-400 wrp
There is a search function. Try typing (Turbo) in it. I found tons of reading. Here is one tread below.
https://www.my.is/forums/f88/na-t-encyclopedia-591569/
If you do not want to dig through everything and figure it out. Maybe this is not something you should try to do.
Here's my plan for you. If you like the IS, keep it as a daily driver. Everyone needs to get somewhere whether its work or school. Then buy a $1000 car (LITERALLY, $1k or so) to work and tinker around with. I started with a 1979 FIAT. You will find, the older the car the simpler it is and the easier it is to learn and work on it. Good luck and have fun!!!
I like that Idea above ! But what about getting another daily and tinker with the IS300 ???? HMHMHM but the rise is just so smooooothh.....
No. The simplicity of older cars is what makes the point a good one. If the guy were an experienced mechanic I'd say sure....but he himself mentioned he was kinda new. Hes talking engine head and then mentioning pistons and rods. Get a 4-cylinder something with ample room in the engine bay and take it apart (mod it if you want to) and put it back together. Fun times.
I always thought this was an NA thing. For turbo's, I figured you'd just turn up the boost to get more air in the engine.
300-400 HP is a pretty moderate goal. I would leave the motor alone and just bolt on some quality parts. The most you would need to do is a GTE head gasket and Arp head studs but even that is over doing it for that power. However If you did go that route I would have the machine shop just look over the head and inspect the valves/guides/seals etc. Maybe a nice deck on the mating surface. The tune will be the biggest factor in the engines reliability. A lot of people spend quite a bit on parts then try to cheap out on a good dyno tune. Don't be that guy.
delete
new to the forums so I know my credibility isn't worth a hoot but I just would like to chime in if that's ok. if 300 hp is where you want to be at the stock ge will take it all day long with a proper tune as mentioned above. your fuel system is the life blood so don't cheap out there, you will probably end up spending more money on that then anything else but it is the key. you could buy a cheap ebay turbo kit and if the turbine failed the you lose boost, just have to change turbine. your fuel system leans out then well you wont only grenade your engine but could potentially cause injury or worse.
with that in mind here is just a couple of the more common builds we have found over the years of trial and error that has saved some brothers a bunch of time money and headaches.
300hp-
even for the 300hp range I still recommend stand alone, wire in parallel and keep all your factory functions, as you will find in a search because it has been mentioned numerous times when choosing a stand alone it is best to consult the person who will be doing the tune. our local tuners still like the aem v2 but I hear great things about haltech and ecu masters. good quality fuel injectors and fuel pump. we have cars that run oem supra fuel pump and 440 injectors, though the AEM stealth is a great alternative, dont like walbro so much but thats just an opinion from years of experience with them.
as for the motor in this power range leave it exactly how it is. yes do a run through make sure everything is ok compression test and such but no need to separate the head and the block. contrary to what some may say the ge vvti rods will handle this amount of torque. no need for head work either "the stock motor is fine"
now a turbo kit LONG SSTORY SHORT.... best bang for your buck we find comes from CXRACING. they have a complete bolt on kit for less then 2k. thicker manifold option as well that seems to hold up, none we seen have failed yet. weak link we find is the wastegate, spend the money and get a good quality wastegate tial or turbosmart is what I recommend, the blow off valve is a cheap kinda one also so get a better quality one when the time is right. or you can look for and shave down the imperfections you come across s it does not get stuck, the choice is yours.
I probably missed a couple of things but that's pretty much in a nutshell what we do for the guys wanting to be at the 300hp range reliably daily driven.
400hp-
now for the guys wanting to hit the 400+ range the set up is pretty much the same as the mentioned above except we do work to the motor. only thing we UPGRADE if that's the proper word are OEM GTE rods and OEM GTE headgasket. that's the only things needed to allow your ge to reliably hit this hp range. however we always recommend changing all the bearings, piston rings, going with arp studs, valve stem seals the works. last thing you want is to have done all this work and have an old main bearing fail or old piston rings go.
at this point it pretty much blows the budget so to say but we recommend you send the head in to get some porting done, whatever you can afford, horsepower is an addiction and if you already have the motor apart just get it all done now to prepare for the inevitable, unless you enjoy taking your engine apart all the time then more power to you lol.
anyways this was just some ideas to throw out there, it is in no way shape or form the right way or only way, these are just our experiences we have with the 2jzge. there is much more we could elaborate on and get specific with but I wont continue this novel to an epic trilogy. if you do have any questions feel free to send a dm, always enjoy talking and learning 2j with people.
I probably should have mentioned the TT piston and rods. Id be hard pressed to buy that over some forged parts. I'm not sure what a set of oem TT pistons and rods go for though.
delete
brand new set of oem gte pistons and rods we get for 300 when they are available, that's with brand new rings and rod bearings, so for 300 to 400 hp range they are more then sufficient and save a ton of money, I think some of the cheapest decent forged rods ive come across are 500 and up??? and that's just rods not pistons, im not sure if id trust the 250 dollar ones out there, and the GE pistons are fine if you are not trying to lower the compression any more, adding the gte head gasket takes it down in the 9.3 range estimated??? for not having so much boost the higer compression helps it not feel so sluggish, of course that is just my opinion based on our own trial and error.
Mind sharing where this can be found? Unless you meant when they WERE available?
Sent from my SM-G935T using Tapatalk
delete
cant say specifically, nothing personal just don't want to post publicly and "a run on the banks" situation happens and there goes the lifes blood of our business... but if you know of a shop that builds brand new 2jz motors that's your source, what happens is they take the brand new short blocks and put all new forged parts, they end up having the OEM GTE pistons and rods available at a decent cost... now that this information is out there im sure the price will skyrocket now with the supply and demand but ohh well it is what it is... get them while you can hahahaha
1 - 18 of 18 Posts
