first post in a long time...I need some help or suggestions with my Brembo BBK. When i first installed them, used from Ryan(Lexus84), they were working perfectly (quiet and could stop on a dime!) After a while, i had to install replacement pads from Brembo.
There's still plenty of meat left on the pads, i guess when i installled the pads, i didnt lube or grease it, i jus took out the old, and put in the new, dont deal. But through barely aggressive driving in the summer, the brakes will start to make that very high pitched sqeal when coming to a stop, so i took the pads out and greased and lubed the pad backing and bolts. But now in the winter, the brembos sqeak and sqeal jus bout everytime i drive the car. I cant find a pattern as to when the sqeak. I thought it was because the brakes were very hot during the summer, they would squeal, but now even in the winter, the squeak and squeal, at almost anything.
Also, anyone know any BBKs with front AND rear setups. I think stoptech's make em for the front and back, I was hoping for 6-piston up front and 4-piston in back, but im afriad that might be too much for this car and might throw off the brake balance. But does anyone know of any other manufacturer with both front and back? I called Brembo, a specialist told me the reason Brembo's dont make BBK for the back is because they couldnt find a sensitive system enough and the wheels would always lock up.
Any help would be great.
