has been doing this for a few days, the brake light comes on and the trac light comes on at almost the same time, and no its not when the trac control kicks in, anybody ever had this problem, what is the cause? :roll:
Mr. Negative
I'd take it to the dealer. I've never hear of brake light and then the trac light. Take it to them and have them check it out. Then post here what they say.
If you have a CEL too then you can get the obdII code read by someone and post it and I'll tell you what the cause is.
Have you checked your brake fluid level? If it's low, that's the usual reason you will get a brake warning light. Not sure why the TRAC light would light too unless there's a tie in somehow.
