I had the "Brake Clunk" issue for the looooongest time but think I accidentally stumbled upon the fix? FINALLY NO CLUNKING!!!!
If any of you have the "Brake Clunk" issue, please see if this fix works for you, too.
I replaced all my brake pads last weekend and did something that I normally don't do... I used a steel brush and cleaned off the brake dust grime and thin film of rust on the retaining clips for the brake pads. I did everything else the exact way I usually do brake jobs.
I didn't notice that it was silenced until later on that day when I backed my car into my usual parking spot. I was waiting to hear the "Clunk" but I didn't hear it! I went forward and reverse about 3 times just to see if it was a coincidence but... It was gone! Wooohooo!
If it is the fix... maybe the grime and rust was hanging up the pads and not allowing them to freely move laterally? I dunno, but heck, I'm happy that the "Clunking" is gonzo.
I've researched this inside and out. Ball joints are fine, caliper pins are okay. Everything looks good except for a torn dust cover on the driver side strut and this... Lexus IS300 driver disc brake. - YouTube . Is this normal? I've changed rotors on other cars and the rotor were bolted to the hub. The passenger side rotor has no play at all. Could this be the problem?
hmm ill have to try this. This bugs the crap out of me. I have 3 toyotas and this is the only one that clunks or clacks so loud, it cant be good.
