81 - 100 of 146 Posts
I'll add mine
2jz-gte vvti swap
Rebuilt GTE shortblock
Rebuilt VVTI head.... vavle job ect
ATI harmonic balancer
BC vvti 264 cams
Dezod AEM PnP
lsd rear
PFS Auto built Trans
PT6265 Billet Turbo
HKS cam gear
custom engine torque damper
PHR springs and retainers
Tial 44 WG
HKS SSQV bov
Bosch 44 fuel pump
full PHR stage 2 fuel system rail, regulator lines ect.
875cc injectors
full custom 3" exhaust
bilstein shocks
eibach pro kit springs
eibach sways
brembo brake disc
only dyno i have is 465 @ 16psi on a 90degree day dyno tune.
Built and Tuned by Power House Racing / Dynosaur Performance
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Apricot idea killer
I'll add mine
2jz-gte vvti swap
Rebuilt GTE shortblock (Japan Direct Japanese Auto Parts) asshats sold me a rod knocking engine!
BC vvti 264 cams
Dezod AEM PnP
lsd rear
PT6265 Billet Turbo
Tial 44 WG
HKS SSQV bov
Bosch 44 fuel pump
875cc injectors
Current Power Levels 465 @ 16psi on a 90+degree very humid day dyno tune.
[/IMG]
You HAVE to fix that I/C or get a larger bumper. Looks great otherwise.
Not pushing much to the wheel, just a little over 300.
I didn't do the best dremeling job but I am content.
I do plan to do a few more mods and push the w55 to it's limit.
I can finally add to this list and it feel really good....
2001 Lexus IS300: Boosted @ 6.5 PSI, 327 WHP...conservative but enough for me...
For video please check out the Dynamotorsports website...I got the 1st slot in june!!!
http://www.dynamotorsports.ca/news.htm
All this thanks to Tony the tiger and Dynamotorsports.ca
Engine:
Precision Turbo HP Technology Series – 62 mm Billet compressor wheel, 65mm turbine wheel(400-6265)
HKS SSQV Version 1
SRT 2JZ Tubular Exhaust Manifold Heat Wrapped T4 Housing
Tial 38 MM Wastegate
Greddy Emanage Ultimate
• Greddy 3 Bar Map Sensor
• Greddy A/F Harness
AEM UEGO Wideband Gauge
NGK Sparkplugs
Walbro 255LPH Fuel Pump, GSS342 and installation kit for 2JZ-GE
• SMP Disc Type High-Z 450cc/min Injectors
Titan Exhaust Cam Gear
AC Autotechnic Boost Gauge and Temp Gauge
K & N Oil filter
Magnaflow Custom 3” Exhaust
Vibrant Performance 3” interlock Flex System
• ECU Reset Circuit “Blackbox”
Suspension, Wheels and Brakes:
Koni Yellow 4 Way Adjustable Shocks and Struts
Tein S-Tech Springs
• 18” Spyn Spider Evo Wheels
• N3000 Nexun Tires
Rotora Drilled and Slotted Rotors
• Ceramic Brake Pads
• Custom Painted Calipers with Lexus Decals
Exterior:
Seibon Carbon Fiber Hood
• AAC Custom Blacked out Headlights with 10000K Halo’s
• 12000K HIDLow beams
Nokya Xenon High Beams
• JDM Clear Tinted Fog Lights
• 10000K HID Fog Lights
• TRD Vis Replica Front Lip
TRD Side Badge
Shinzo Media Flat Black Vinyl Wrapped roof
Advanced Automotive Concepts Version 1 Carbon Fiber Trunk Panel
• Blitz Style Carbon Fiber Grill
• Blitz Style Carbon Fiber Eyelids
• Custom Painted black Lexus symbol
Interior:
• Custom 3 pod Gauge Case
• F700 BT Pioneer Head unit with Ipod Integration and GPS
Scosche Head unit Kit
JDM Carbon Fiber Shift knob
• Advanced Automotive Concepts Carbon Fiber A,B and C Pillar
AudioBahn A8000T Mono block Amplifier
• Custom 2 12” subwoofer enclosure with skipass display panel
• 2 X 12” Eclipse Subwoofers
• Advanced Automotive Concepts Ambient Trunk lighting in Amber
I wanted to complete a few more things before posting (clutch, water meth etc), but here goes anyhow.
"Project OE like track-able boost" = meaning no lumpy idle, CEL, gas smell, drone, hearing loss, SoCal Cop hard-on, survive a day at Streets of Willow boost-- yet on a budget (no V160 etc).
OE 2jz-ge, OE compression.
- Two step .035 gapped Iridium plugs
- Components from Turbonetics kit---
- Log manifold, 60-1 hifi ceramic BB turbo
- Custom 3" downpipe to custom 3" midpipe with 3" metal cat-- wastegate recirced
- relocated MAF and BOV, BOV now synchronic, not too quiet, not too loud.
- B2S2 behind 3" cat, no sim, no CEL
- B1S2 simmed with TS PNP Delete
- TS Edition EMU (PNP, 2.20, VVTi control, IAT/Knock input, remote map switching upgrade)
- PNP drop-in 440cc injectors with OE Air Assist delete.
- TB coolant bypass
- Innovate LC-1 wideband
- HKS DLI with TS PNP harness
- TS PWMC Gen II module to progressively control with aux map water/meth injection
- OE W55, OE LSD
- Tein Flex w/ EDFC
- A51 STB, TRD rear STB and underbody. Figs MEGA arms, Okiyama 6point cage, Hotchkis sways, V700 245/275, West End Darin Alignment and corner-balance.
- 2TGEU edition catch can, customized to catch better- placed on PCV intake side to catch possible back-flow blow-by before entering pre-turbo intake.
- Custom Setrab thermostatically controlled oil cooler
- Upgraded PS steering cooler
- C/F OE style hood paint onyx with OE type hood vents
- Prototype TS engine damper
- Fan override switch
- Battery relocated to trunk
Future-
- Probably R154 or AR5 tranny swap
- Manual or EBC
- ABS to old battery spot
- Custom quiet cat-back system
- KW V3 replacing the Tein Flex
- Gray Sparco reclinables replacing the black Sparco buckets.
- HKS Camp system or equivalent
- MSIIIx prototype testing
LC-1 display on cage
TS Edition EMU remote map switching upgrade header installed in EMU circuit board
TS Edition EMU remote map switching connector in place, remote switch that fits into OE blanks
Hood vent
Engine shot
AEM water/meth pump for pulse free TS PWMC Gen II module water/meth delivery
3" downpipe to 3" cat
Figs with meaty V700 275
Battery to trunk
Can't hunt down an intercooler shot, but it hides behind the OE bumper fine.
Alright here is my car! I will be redoing my setup over winter for even more power and torque!!
Engine/Drivetrain
2001 E-Shift
Stock engine with 2.5mm HG
ProCharger P1SC-2
2.085 6 rib pulley (13psi)
Toyomoto Header
Megan y-pipe
Apexi Cat-back
2.5" intercooler pipes
Turbo XS BOV
31x3x11 intercooler
525cc Precision injectors
PnP v2 AEM EMS w/ 3bar map sensor
BC 272 cams
BC springs and titanium retainer
BC oem size valves intake/exhaust
Unorthordox Cam gear
Brakes/Wheels/Suspension
Supra TT front brake swap
17x8 +45 front 17x9 rear RPF1's
TRD Red sway bars
Stance GR+ coilovers
Upper front strut bar
Over Winter
GTE internal swap w/ OEM HG
Built trans by PFS
3300rpm stall converter
Water/Meth injection
1.48" pulley (18psi)
Dual HKS SSQV BOV's
750cc injectors
Mazzuri v2 headers with custom y-pipe to 3" magnaflow exhaust
C-West Body Kit
Chassi under bracing front and rear
I am sure I missing some stuff but oh well.
2003 Lexus IS300
eibach sway bars
Tien Flex Coilovers with EDFC controller
freshly painted Hood, Bumper, Fenders
HID fog Lights 3K bulbs
35% window tint, even the windshild.
smoked vent visors
Performance:
turbonetics kit
3'' Custom Turbo back exhaust with CAT and magnaflow muffler
wastegate dump tube (screamer pipe)
fidanza cam gear
AEM FIC with Boomslang PNP harness
walbro 255 pump
fuel return kit with aromotive FPR
fidanza light wieght flywheel
RPS Blue 6 puck clutch
W58 Transmission swap
Factory LSD
my own custom made gauge pod
greddy weighted shift knob.
The car made 330whp on 8.5 lbs and has seen 11psi (350-375whp)ish
Pics to come soon...
2002 Ibp
Original 5speed converted to v160 with rps clutch and sequioa drive shaft
Swift racing turbo kit with new billet 6262 with 68. ar
arp head studs and gte internals
haltech e6x
still needs some more work
my new setup:
1jzvvti swap w/r154
hpf clutchw/act pp
custom driveshaft
6765 precision turbo
1000cc injectors
twin walbros
greddy catch can
tail 44mm wastegate
tail bov
custom fuel lines/return lines
custom exhaust manifold
custom polished piping
custom polished intake manifold
custom polished valve cover
custom polished intercooler
-2JZ-GE manifold T4, stainless TIG welded and braced
-Down Pipe, Stainless TIG welded with V-Band and football flanges
-V-Band clamps
-Gaskets (DP, header, turbo, oil fittings, etc)
-Oil Lines kit with all fittings and flanges
-24x12x3" FMIC
-44mm Wastegate
-full custom 3'' exhaust downpipe back
-T4 67mm Turbo
-50mm V-Band mount Blow off Valve
-Intake pipe
-AEM FIC o2 UEGO
-tripod Boost Gauge
-FMIC Piping
-Fuel Pressure Regulator
-Walboro 255LPH Fuel Pump,
-GTE Headgasket
-ARP Studs
-tranny cooler and vb upgrade
close to350-380rwhp @11psi no dyno sheet :(
Turbo IS300 2jz-ge T - YouTube
<iframe width="560" height="315" src="http://www.youtube.com/embed/-mT1hNmDHU8" frameborder="0" allowfullscreen></iframe>
2001 is300 na-t
2001 Lexus IS300
Engine Mods
-2jz-ge block, stock crank, eagle rods, acl bearings, 8.0.1 86.5 je pistons,
-2jz-GE(VVTi) Head fully ported head with stock valves, 272 cams and springs zero settings not degreed vvt active
-Fueling 660cc injectors, aeromotive 340lph pump, aeromotive rrfpr, returned modified fuel rails
-Turbonetics 71/63 supra intercooled system, six into one stainless manifold full three inch exhaust
-Greddy emanage ulimate
-Boomslang harness intake sensor and coolant sensor
-IS300 stock ecu, stock maf sensor,
-Add ons Greddy 3bar 5v map sensor
2001 Lexus IS300
Engine Mods
Does your BOV cause any turbulance for the MAF sensor? A better place would be right before or after the intercooler.
Bybee's old car finally breathes fire
'03 IS 300 BO
2JZGE motor
Supra crank
Crower Rods
CP Pistons
1200 CC RC injectors
Stock head
FFIM
PTE 6765
Dual Warlboro 255's
V160
Pump Gas
544 HP at 18 pounds
IS300.MOV - YouTube
