21 - 40 of 146 Posts
turbo...
1. Custom turbo kit, 2001 with E sh*t, stock trans for now...
2. Turbonetics t3 t4 hybrid at 13psi, Precision turbo pte-63 on the way...
Turbonetics godzilla BOV
Turbonetics Racegate
Toyomoto cast manifold, jet hot coated
Toyomoto head gasket
I believe it's a blitz intercooler
2.5" downpipe and factory cat back... 3" toyomoto downpipe
and 3" exhaust on their way....
Innovative Motorsports Wideband O2
Greddy Profec b boost controller
Apexi SAFC.... haltech in three months
rc engineering 440cc injectors
stock block
aeromotive fuel pressure regulator
walbro fuel pump
custom ic piping
Split Second on the way
JIC FLT A1 coilovers
18" manaray's on falken azenis 235/40/18 some rubbing issues
VIZ carbon hood and cwest body kit on the way....
http://briefcase.yahoo.com/wcso31018 Pics are here...
Best dyno is 295whp as of now... Will be much higher with new
engine management system No time slips as of now...
Thanks to RPM performance, Sals performance shop and the
members of is300.net for helping me with various problems and
install tips...
TIP: If you are going to buy a IS300 that already has a turbo kit,
do some research and don't just go buy one... This tip has cost me
5 grand and counting...
500 whp goal eta... hopefully this time next year...
***See my signature for additional information***
TBKO Stage 4 Supercharger
Engine:
ATI Procharger C-2 Supercharger housing
Small SC pulley (pushes 11-13 lbs of boost)
TBKO designed SC bracket with routing pulleys
Larger serpentine belt (one used for entire system including SC)
Large Spearco front mounted intercooler
Mandrel bent Aluminum piping (polished)
Blue silicon couplings
K&N filter
2mm head gasket
Extra fuel injector
Greddy E-Manage (unlocked), editing software extra on request
Walbro 255lph performance fuel pump
Braided steel fuel line for extra injector
Turbo XS Blowoff valve
NGK 3330 spark plugs
Transmission:
TBKO Valve Body upgrade
Front mounted B&M transmission cooler
Toyomoto Stage 2 Turbo
Engine
PT63Turbo
Tubular Manifold
Tial 40mm Wastegate
HKS 264 Exhaust Cam
Greddy Typs RS Blow Off Valve
Haltek E6K
MSD DIS 4
550cc Injectors
Aeromotive Fuel Pressure Regulator
Toyomoto Headgasket
Toyomoto Custom Fuel lines and Return
Fuel Pump Walbro
FMIC
Aquamist Water/Alcohol Inj.
Tranny
Auto to Manual R154 swap completed
HKS Twin PLate GD Max Clutch
TRD LSD
Misc
Stoptechs 13in drilled rotors w/ 4 piston calipers
Blitz SBC-ID Boost controller
Clarion 7in DVD/MP3 Player
Autometer Fuel Pressure/Oil Pressure and EGT Gauges
Numbers
504 rwhp 23 psi (auto tranny) Old setup on 2 1/4in exhaust
360 rwhp 16 psi pump gas (auto tranny) Old Setup
[email protected] 2.1 60 ft (auto tranny) Old Setup
NOW I CAN ADD TO THIS LIST!!!!
TOYOMOTO STAGE 1 SUPERCHARGER
-new toyomoto signature bracket with "toyomoto engraved"
-Rotrex supercharger
- Toyomoto bracket,
- Toyomoto Front mount intercooler
- Front Mounted oil cooler,
- Blow off valve
- Toyomoto fuel system,
- 6 high flow injectors
- Air intake system
- Toyomoto electronics
.....more to come, I lost the list...LOL :lol:
TOYOMOTO SHORT SHIFTER
Toyomoto headers and race pipe
Greddy evo + b-pipe
Lsd
Apex'i SAFC II
Cosmetic:
PIAA 9006 ultra blue in jdm fogs
15% TINT
ICHIBAN SHIFT KNOB
INTERIOR LED SPOTLIGHTS
NEON UNDER THE DASH
NEON IN ARMREST(ski port)
NEON UNDER CD-changer
PASSPORT RADAR HARDWIRED
BLINDER
JDM TRD & ALTEZZA EMBLEMS
JDM ALTEZZA GRILL
JDM Altezza Clear FOG lights
JDM TRD Radiator cap
PIAA-Xtreme white plus high beams
PIAA-H-325 led parking lights
Clear sidemarkers
LED DOME LIGHT
LED LICENSE lights
S2000 Antenna
SUSPENION:
TEIN S-TECH SPRINGS
Camber kit
Spring Spacers
WHEELS:
AXIS NE-O (Chrome) - 19x8
Nito Nt555 pro 225/35
AUDIO:
(2) 12INCH JL V2 W3'S
BANDPASSED
CUSTOM BOX
PORTED THRU SEAT
PLEXI GLASS
500W AMP-SUBS
300W AMP TO STOCK SPEAKERS
EXTRA BATTERY
PG WIRES
0 guage wires
NEONS in the box
CUSTOM PLEXI GLASS AMP RACK-W/NEONS
Mini fan to cool down sub amp.
Viper Alarm
PICTURES:
BEFORE:
System:
Boost and Scenic Pics:
Diverter Valve:
Guru of Supercharged ISs
FINALLY...!!!!!!!!! & almost done...
THANKS TBKO & Jae Kang!!!
SPECIAL THANK YOU to:
LUXURY MOTOR WORKS,
.....for everything!!
TBKO Stage 2+ Supercharger System:
ATI ProCharger/ C-1
Custom Luxury Motor Works Alloy/Anodized Mounting Plate.... MORE custom work coming..........
24x8x3 TBKO Custom Intercooler
'TBKO' Stainless Steel header & XERD Race pipe w/Custom Hi Flow Cat.
Borla Stainless Steel Full Catback exhaust system
Walbro 255 lph Fuel Pump
Greddy Emanage Ecu
Zeitronix ZT-2 Wideband O2 sensor w/A/F-Boost-EGT, in-dash display
Toyomoto 'O2 sim.
Titan Motorsports 5 bolt Adj. Cam Gear
Unorthodox Racing Liteweight Alloy Accessory Pulleys
Unorthodox Racing Ultra-L Liteweight Alloy Flywheel
RPS 'Sport' Pressure Plate & Disc
Custom Oil Catch Can w/Braided steel lines
Remote Mount, Dual Filter/2 Stage Oil Filtration System w/Custom Machined finned billet alloy heat exchanger & and a Custom fitted MOCAL/Aeroquip Oil Cooler w/Aeroquip Braided steel Hoses & XRP Fittings.
Amsoil Synthetic Oils & Oil filters
APR Carbon Fiber Radiator Panel
Injen Header Heatshield
SUN HyperVoltage system,& HyperGround Kit+TECK Ground Kit (Combo)
Odyssey/Hawker PC980 Drycell Micro Battery (mounted in trunk)
http://www.cardomain.com/memberpage/349810/15
dyno numbers coming soon I hope.....stay tuned.
:crazy: :crazy: :crazy: :crazy: :crazy: :crazy:
Custom set up . Pieced together by me and put together by my friends and I
-Electromotive Tec3 ems
-Greddy T78
-TT pistons and rods
-ARP head studs
-HKS cam gear
-Tubular stainless steel manifold
-3.5" DP
-3.5" exhaust piping to a 3.5" inlet tanabe muffler
-custom super huge intercooler with apexi and tanks and custom 3" intercooler piping
-greddy type R BOV
-ITS progate racegate
-return fuel system w/ aeromotive FPR
-warlbro fuel pump and inline pump
-720cc injectors
-still have 5 speed for now (rps clutch and UR flywheel)
-gs400 throttle body
-greddy profec b boost controller
-greddy boost and egt gauges
-greddy timing belt
-custom intake y pipe ( shortened )
No dyno numbers as of yet.
Thanks to Jeff and crew at TurboEast for their amazing work and service, all my goals have been acheived and then some. I received an outstanding product producing outstanding performance at a reasonable cost! His customers can always expect to be well taken care of…even after the sale!
The supercharger did wonders and I was very happy with it, but after reevaluating my preferences and goals, I decided that changing over to a turbo better fit my needs.
Facts about my old Supercharger setup here: http://www.is300.net/forums/showthread.php?t=198971
One of my main goals was to have myself a 12-second every day driving sleeper.
I could have reached that 12 second goal with the supercharger and in fact had planned on Jeff doing some other modifications to reach that goal such as a bump back up in compression from 9:1 to about 9.5:1, return fuel system, and other stuff, but then decided that it would be more economical for me to convert to turbo since I decided to stop being ignorant to myself in saying that I would be happy once I reached my goal and wanted the ability to tap more power in the future if I decide to. With the supercharger, I could have reached my 12 second goal with stall converter, drag radials and the other stuff mentioned above, but when I met that goal, that would have been all the car could achieve without adding something like nitrous on top of the supercharger in order to go faster.
MY TURBO SETUP…
A Special Stage 3 (SS3) Turbo from TurboEast. I may end up being a one-off, but if you have interest in this kit, call Jeff about the production of any additional kits of this type in the future.
Parts List (many new, many already existing):
Garrett TE63 turbo (Polished)…TE spec’d
TE 2mm Head gasket
TE turbo header (Polished)
TE Down pipe
TiAL 38mm Wastegate
Turbo XS Blow-off valve
Dual stage TurboXS manual boost controller
TE Custom remote dual stage boost switch (13psi & 15psi settings) in PAS COMP
Walbro 255lph Performance fuel pump
TE Custom fuel return system w/ fuel pressure gauge and regulator
TE Custom ECU open loop switch in engine compartment
RC Engineering 440cc fuel injectors
26”X13”X4” Polished intercooler & all aluminum IC piping
TE custom 3” exhaust to mid-pipe
Greddy Cat-back exhaust system
Greddy Billet aluminum oil catch can
TurboXS Wideband and tuner
Auto Meter PRO-COMP Boost gauge (custom mounted inside glove box)
Greddy E-Manage w/ boost sensor, ignition harness & injecton harness
ACIS Valve eliminated
NGK 3330 Spark plugs
TE Valve body upgrade
TE Transmission cooler
TE Stall Converter (2,800rpm)
TE Electronic Shift Kit (ESK)
TeCK Grounding Kit
Pictures of the Parts (This is a 90% solution...I'm getting a turbo blanket which will allow me to take off the heat wrapping on the coupling and changing out the black vacuum tube going into the oil catch can to braided steel line, among a few other things:
Remote Boost Controller Switch (13psi and 15psi setting):
TurboXS Wideband and Tuner:
Front shot, note Greddy Billet Aluminum Catch Can:
TurboXS Dual Stage Boost Controller:
The Downpipe:
TE Custom Return Fuel System with Fuel Pressure Gauge:
TE Custom Return Fuel System with Fuel Pressure Gauge (2):
Note the beautiful Turbo Header:
Note the beautiful Turbo Header (2):
Daytime Frontal Shot:
TurboXS Dual Stage Boost Controller, close up:
Garrett TE63 Turbo and Turbo Header, close up:
NOPI Nationals 2004 PICS (Placed 1st in Conservative Class and 2nd in the 6cyl F/I Dyno Competition):
Sorry, had the trunk open and didn't realize it...the gap is normally not that big...lol. :blush:
Dyno Performance (ALL #’s ACHIEVED AT CONSERVATIVE TUNE SETTINGS):
13psi (My everyday driving boost):
PUMP GAS
15psi (My track and if I feel like being rascally on the street boost)
PUMP GAS
17psi (Easily obtained and a bragging right dyno only boost for the most part. I may decide to ¼ mile this number with C16, but I’m debating risking my tranny or parts of my drivetrain)
Partial fill with C16 RACE GAS
Comparison dyno chart depicting the power bands for all my boost settings overlayed together:
Note the 11psi (As a test since my SC was running this boost level. This is not a boost setting my car uses):
PUMP GAS
¼ mile performance (Spinning, normal operating temperature, P225 tire, no LSD, no stall converter, spare tire taken out):
ALSO KEEP IN MIND, THIS WAS MY FIRST TRY WITH THE NEW TURBO SYSTEM...THE NUMBERS WILL DEFINITELY GET BETTER ONCE IT GETS COLDER AND I ALLOW THE CAR TO COOL A LITTLE MORE
13psi (pump gas)
Climate: Noted in timeslip
15psi (pump gas)
Climate: 60's, cool night. Very nice.
17psi (C16 race gas)
Climate: n/a
TBD…maybe.
NOTE THE ALMOST 117MPH TRAP TIMES WHICH MEANS THAT I'M WELL INTO THE 12's AND POSSIBLY 11'S IF I CAN GET A DECENT HOLE SHOT...***cough***STALL CONVERTER AND DRAG RADIALS***cough***
Gas mileage:
CITY: 15-17mpg
HWY: 24.3 – 21mpg depending on my friskiness
Drivability:
Sound: The loudness of my car went down by about 10 fold in comparison to my SC setup, despite the turbo header and 3” exhaust to my cat-back. No joke, my car now sounds like a N/A’d IS300 with a HKS hyper as the only mod…and I know what that sounds like. Even at WOT, the loudest thing going on for me is the wastegate throwing excess air into the atmosphere. I haven’t heard too many turbo BOVs in person, but I can’t imagine a BOV being any louder than what mine does. I’ve scurred too many people already with that thing. Man is that BOV addictive!!!
Idle: Stock…sometimes minor hiccups at idle (like cars with larger cams do every now and then) when first starting up the car after it’s already warmed up and has been sitting awhile, but that’s it. The car starts much easier now with the return fuel system. Only sometimes it takes a couple of seconds to crank to a start.
Acceleration: Freakin’ fast! Fast when at normal boost, then when I flip the switch it is sick fast!!! When I was running only ~330rwhp (the hp before Jeff could dyno tune it) the car had already felt 3x faster than with the supercharger. I credit this to the monster torque and overall power curve. To prove the fact, here’s a tidbit. Even though I had only ~330 rwhp, I had about 90 more rwtq throughout the majority of the power band than the supercharger!
Shifting: The shifts in my TE VB upgrade is much more refined now…probably due to the change in power curve. It shifts much smoother at part throttle and low RPM shifts, but still retains the throw your head into the headrest kick when shifting at WOT…if the tires catch hard that is. With the 15psi setting, my rear end does a little waddle during the 2-3rd gear shift usually.
Traction: Still not many problems on this end while on the street, but at the track I was getting more wheel spin than I ever have...enough to know that I'm loosing at least .2 seconds off the 1/4 mile E.T. I think my P225 Yokohama AVS ES100’s are relatively sticky, so other than getting slightly sideways on shifts sometimes and the track, I don't think I'm doing too bad in this department.
Turbo lag: Just note my 60' times...I'm slower in my 60' now by .2 seconds than when my car was stock. I must get a stall converter! However in reference to every other situation on the street, I am happy with the turbo selection b/c it seems to ride on the edge of big enough to produce mad power and small enough to spool incredibly fast for what it is.
Heat: The turbo header absolutely helps me out in this department. I am truly amazed at how cool everything stays under the hood. When I first got the car and opened the hood for the first time when the car was at full operating temperature, I expected to get blasted in the face with the extra heat over the SC, but it just didn’t happen. The reason must be because I don’t have a cast iron turbo manifold under-hood which means temps are much lower than usual for most turbo setups….yay!
Running piggy-back ECU: I’ve never had problems with this system and still don’t. Jeff has a “special” solution which prevents the stock ECU from “relearning” the settings input into the Greddy E-Manage. I have had the opportunity to closely monitor the wideband for while now and have not seen any changes in A/F ratios during cruising, idle or WOT. For those who are still non-believers, here I am : ) Do I wish I had a standalone? Yes and no. Yes if you gave me one for the same price as the E-manage, no if you tell me I have to fork over another $1,500-$3,000 for it. : )
Funability: I’ll just have to take someone out for a ride, it’s beyond time, space and imagination! There’s no way to describe it other than feeling like I am in a high-performance jet.
~SXiS
Bought the car with the toyomoto stage 5 setup since then....
New gte block
Supra pistons
Pautter Rods(transferred from oringinal engine)
272 cams
HKS cam gears
ported head
oversized ferrea valves
spings and retainers are on the way
dual HKS super sequential BOV
Nitrous express intercooler sprayer
Tanabe pro coilovers
L-tuned sway bars
ROTORA upgraded brakes
19 Motegi Racing Wheels
There is a lot of other cosmetic stuff on the car as well. I am doing the work myself and just waiting for the machine shop to finish the head. It should be running within a couple weeks. I will post dyno results as well as pictures and a full list of the upgrades when the car is finished.
Swift Racing Stage II with Haltec fuel management.
8.5 psi = 345rwhp
track time at 7psi = 13.7 @ 106mph (NO TRACTION)
stock 5-speed tranny, RPS clutch
so how many boosted IS3's are out there?
Totally forgot this list existed.
2003 Graphite Grey Pearl 5MT IS300
Boost Logic IS300T Kit
BL61mm turbo
IS300 SS321 T4 Tubular Manifold Ceramic Heat Coated
HKS 40mm Wastegate
SS304 Polished Dump Tube
IS300 SS304 T4 Manifold Adaptor
SS304 3" Polished Vband Downpipe
SS304 3" Polished Midpipe
SS304 3" Polished Midpipe Adaptor
Boost Logic -3AN Oil Feed and -10AN Return Kit
3" Aluminum Mandrel Bent and Polished Intake Pipe
HKS SSQV Blow Off Valve
Walbro 255LPH High Pressure Fuel Pump
Custom Machined 50lb Injectors
Aeromotive -10AN Fuel Pressure Regulator
0-100PSI Fuel Pressure Gauge
Boost Logic Fuel Return Kit with AN Fittings
ARP Head Studs
3 Bar Map Sensor
GM Intake Air Temperature Sensor
Boost Logic T4 Turbo Blanket
PFS 3" cat back
Upgraded 6puck ACT clutch
TT pistons, rods, headgasket (machined, balanced, yada yada yada..engine shop took a long ass time)
Electronics
TEC3 Standalone (waiting for Justin to retune it)
Blitz SBC iD electronic boost controller
PLX Devices M300 wideband
Blitz Turbo timer
sleeper look
didn't get a chance to clean the piping
dirty tubular header
mid pipe
dyno'ed at 12-12.5psi earlier in the year.
More pictures to come after I get back from China and motor/clutch are broken in. Going to get Justin to retune the TEC3 for the new setup and then dyno with a higher psi on pump.
Driving Impressions
Haven't gone past 4000 rpm as I am taking it easy during break in period but the car drives very smooth, almost stock like. But notice the power jump as the car approaches 4Krpm, thats when all hell breaks loose and stock tires start smokin' ;) (This event was experienced while I had my old setup, same turbo size)
More to come...thanks guys
Chris
heres my ride just finished started in fall of 04
specs:
used SRT stage II old kit with turbonetics turbo and e-manage
Turbo East 2.1 mm head gasket
Turbo East little Black box
Greddy type s boost controller
zetronix wideband/press/egt
trd gauge pod with Blitz gauges press/egt/fuel press
blitz turbo timer
titan cam gear
PFS 3" exhuast powder coated black other that tip
custom powder coated IC piping and exhaust mani and down pipe
-Brett
drive by links removed..
2001 MSM E-Shift Pushing 7-8 PSI
Vortech V2-SQ (Super Quite) supercharger unit
GTE Bottom end
TT HG
LMS Piping
PWR Intercooler
B&M Tranny Cooler
Toyomoto VB
Pro1 Header @ Race pipe
Greddy Exhaust
LMS I-Manage
Zeitronix Wide Band
Defi Boost/Oil/Fuel pressure
H&R springs
Tokico Illumina
PLP front and rear Strut bars
LMS BBK
Pics:
-=Completed=-
Toyomoto Stage 3 Turbo Kit
Or what I like to call stage X or Stage 7
Drop off: May 13th 2005
Pick Up: August 15th 2005
Engine:
Garret GT35R .68 A/R
Toyomoto Tubular Manifold
80mm Throttle Body (LS400) thanks DAS
Shaved Intake manifold
20x10x3 Front mount intercooler
3 inch Intercooler piping from the intercooler to the TB
3 inch inlets on the FMIC
2.5 inch piping from turbo to intercooler
Vortech blow off valve
Supra TT Internals (pistons, rods, rings, bearings)
Boost Logic Turbo Blanket
Haltech E8
Toyomoto return/fuel system
Walboro pump
720cc injectors
Tial 40mm Waste gate (open dump)
HKS Hi Power 3inch muffler (angled up and out)
3 inch exhaust
3 Inch down pipe
No governor
1mm head gasket (TT internals)
PLP non vented radiator panel
Transmission:
W58 (SC300)
-Clutch masters double diaphragm Kevlar disc
Electronics
Defi BF White Boost 60mm
Defi BF White Oil Pressure 60mm
Defi Control Unit II
AEM UEGO Wideband (Silver)
Blitz SBCID III
BRAKES:
Brembro front and rear brakes slotted and drilled
Axis ceramic brake pads
PICS:
http://www.aturbolexus.com/gallerym.html
More info/updates/pics/meets/ etc on my personal website:
www.aturbolexus.com
-JOSH
