backround:
Radar detector
Equalizer
remote wire to amp
are all hooked up to the cig lighter power&ground wires, and I keep blowing fuses...
So I literally unhooked and taped up every connection, nothing is touching eachother, and I'm still blowing fuses.
HELP?
i think you have too much hooked up to that cig. lighter... i would either try to seperate some of them or try adding a higher amp fuse :confused:
I unhooked everything.. there is literally nothing hooked up to the cig wires. and I tried a 20amp instead of a 15, and it was a no go... it worked fine this morning then all of the sudden the amp cut and i realized the fuse was blown..
i'm stumped :confused: so you have an aftermarket audio system in your car? you might have a short going on with the way that was set-up?
I still would break up the load and find another spot for one of the items.
D
