So im about to unplug my negative terminal to reset the ecu after i installed the racepipe and SRT intake when my friend says stop.
he lifts the cover to the fuses and pulls out the EFI fuse and the ECU fuse and puts them in after about a minute. ecu reset.
much quicker then pulling the negative. just thought id share
you can also try turning on the interior lights, or your sun visor lights.
OR
you can press the brakes for few secs.
btw, Lexus says their ECU can hold memory for as long as15min after its battery dies, so fuse, lights and brake method is definately the way to go.
