I have an ’03 e-shift with just under 24,000 miles on it. Recently, when I start up my car, I notice a somewhat high pitched noise coming from the front under the hood. It sounds like it’s a belt of some kind, because when I shift into reverse to back out of my parking spot, the pitch gets just slightly lower and the “chirping” kind of sound that it makes slows slightly. I don’t know too much about the mechanical stuff of the car, but it sure sounds like it’s a belt of some kind. Is this normal for a car with less than 24,000?
I don’t wait long at all for the engine to heat up before I start driving, so I can’t tell one way or the other if it does away after the engine heats up, because I’m on the freeway in 5 minutes. However, before I get on a main road, if it’s quiet enough when I pull up to a stop sign or stoplight, I can hear the chirping at the beginning of my commute after I leave the parking garage (I can hear it much easier in the garage obviously too).
Let’s see…more background info that might be of any help. I just do normal driving, no auto-x or anything like that. Obviously I have a little fun every now and then on freeway exit/on ramps and all, but nothing crazy. I did just completed a road trip from Los Angeles to St. Louis however as I relocated jobs. Not sure if that’ll do anything or put anymore abnormal stress on the car. Took 5 days, stopped in some National Parks in Utah on the way out, otherwise did 75 or so consistently on the highway. I was on paved roads the whole time.
I think that’s about it. I’m sure this is something common and I’m rambling on and on here for no reason. Any cost/warranty coverage if it’s a simple belt problem? Thanks.
(sorry if this is in the wrong forum)
