1 - 20 of 20 Posts
Hey guys, haven’t posted in a while, but finally got around to installing the BC Stg II cams that I purchased a while back. First start up went smooth…now just need for this shitty weather to break to go put some miles on it!
Vehicle Hood Car Automotive air manifold Motor vehicle
Thanx guys! It still needs a little more TLC, but I'm installing a lift soon in the garage, so that should make further detailing much less painful!:)
Definitely interested in how it drives
Ok, so finally had a decent enuff day yesterday to take it out of the garage and go for a test spin! I can def say that it pulls a little harder in the mid-range and upper rpms! I mean it's not like adding nitrous or anything, but the difference is noticeable! :)
Did you retard the exhaust gear any?
Discussion Starter · #14 ·
So, I had it set to -3.5*, and changed it to -2*…because I had read that it may throw a CEL after installing cams if you get too aggressive w/the retard. So far, so good at -2*…we’ll see if it stays happy there.👌
Depends if you have downstream O2 sensors simulated. If so no. Even without, I have seen no evidence. I have seen -4 but not more.
Can anyone point to verified dyno data of effect of retarding exhaust cam?
It was a long time ago on the forum. Back in the is300.net days. It was -4 on these cams and also stock stuff. No one has posted a sheet sense. I have seen and done more stock. Just have not had a chance to see if it can push broader with more on stage 2 cams.
1 - 20 of 20 Posts
