21 - 36 of 36 Posts
THE MAKER
Discussion Starter #21
very true. I am very impressed with the BC's and love my set up. never would I think that a coilover priced so well would perform outstanding. thumbs up to BC racing on there awesome coilover.
does anyone know the stock spring rates?? I think they are around 18k and 14k but thats just a guess and seeing the massive coil spring. please if anyone knows that would be a huge help or if anyone in so cal has stock springs laying around can i borrow them to get dyno'ed to find the rate.
THE MAKER
Discussion Starter #25
IMO, the stock spring rates cannot be that stiff. They seemed much softer at speed that the BC's and over damped. I can see what they are from my stock setup that is sitting here.
Fig
Mike, please find out if you can. I know you can help. thanks
Am I Hype-R???
Fig
so has anyone found out what the stock spring rates are??? :)
Technical Poseur
I'm guessing the 12k/10k range. I rode in an IS300 with those rates and it was night and day difference in stiffness over my 10k/8k setup on my IS. ISx50s arent really much heavier of a platform than the IS300. It also seems to have been softened up for that generation as well.
Man, those kw v3 look sweet, glad i have them in my car.
Hahaha.. I forgot what that was like!!! Sorry, no offense, I love the car,and those coils look great! I wanna drop just the front end of mine.. too much trouble with tire wear and tear with the whole car dropped.. Im a realtor, so put a ton of miles on cars and go through rubber like its part of my job... which i guess it is ;)
THE MAKER
Discussion Starter #35
yeah I have put on about 18K the first year, so I do a bit of driving myself :) Tire wear is not too bad on this car, even with no adjustments since the suspension geometry was designed to be lowered. I need to realign the front steering, but other than that, no problems.
Fig
Awesome Pics and info!!
Besides the Weight and Rate (valving) being different, are the ISF, IS250, IS350 and IS300 Shocks physically the same? I noticed you compared it to the IS300 KW which Looks like the bottom mount is the same, could you swap the top hats and mount them if needed / wanted? Are the Front shocks for the IS300 KW bottom mount the same as well?
I am just curious because I thought the 2ng gen IS shared more with the 2nd gen GS suspension wise instead of original IS300.
21 - 36 of 36 Posts
