asukadc said:The shift knob from a stock one doesn’t screw back 100% tight, it spins a little
asukadc said:I am so used to stock shifter for the past 30k miles or so, used to do heel and toe and now the timing is little different, getting re-adjusted, about 1 hr of driving got me back the feeling
i second that =)rofl said:Wow, you drive with it very cold in your car
Can you post a link to B&M site so us n00bs and find the product? thanx
typeo65 said:I just installed mine, and I'm wondering if it's louder than it's supposed to be. When on the gas there's a higher pitched, almost wind like noise. When I let off the gas it changes tone. Is this the whining noise people speak of?
No not really.AntzLexusIS said:Yessir this is what the whining noise we all speak of. I think by changing out the fluid it goes away. Or so members have said?
Seven0Three said:i'm definantly pleased with my B&M shifter install, but i still have the notchy feeling between 1st and 2nd gear. and i can't get into 1st unless the car is at a dead stop. and this is after i did a drain refill on the tranny and diff.
I use Amsoil and it whines. The OEM shifter is filled with a rubbery sound deadening material which is why it is quiet....the B&M is solid metal.No not really.
I have redline mt-90 tranny fluid and it still whines.
I put some dynamat around the shifter stalk and it helps with some of the chatter and noise, but it does not eliminate it all.
CEB said:You need to learn to double de-clutch on this IS to do this.
As you are rolling to a stop at say 15-20mph...
push clutch
go to neutral
blip accel
push clutch
go to 1st gear...it will effortlessly pop into gear when the revs match.
you can do this heel and toe or just the regular way and it does take practice.
I had this problem with the first B&M shifter I had...It would twist a little bit.Seven said:A question for you all. I've been working with B&M now for a month, because of this problem: The shift knob twists a bit left and right. It was really bad at first, but they send me a new main shaft for the shifter and that seemed to help a bit. Part of the problem with it being a multi-piece shaft, is that it has gaskets between the main shaft, and the top shaft that slips over it. The pin used to connect those two together also has gaskets in it.
Anyone else with the B&M have this problem?
