1 - 16 of 16 Posts
Just installed Axxis Deluxe Plus. Initial feel - it has better bite when it is cool than stock pads. Brake pedal feel is still progressive like OEM pad. Definitely better braking performance that my 70% worn OEM pads.
Sorry didn't get on the track yet so no Performance review.
Cost.
Got pad from Ebay - local seller. $85 frt & rr set local pickup
Turn rotors - $15 front only. rear rotor still smooth
disk brake quiet -$2.25
Just slightly breaking $100 mark for both axle. Sweet.
I also painted the rusty rotor with "High Heat" Aluminum. So rotor looks new for now. Let see if the "high Heat" paint will withstand the temp. $5 for spray paint if you want to tally that too.
jedi said:
Report back in after a few 100 miles. I am curious if they start to squeak on you.
Thanks
I 2nd this request.
I plan on stepping "down" from my current Axxis Ultimate pads...when they wear out. Too aggressive for the street.
Thanks
Mine have not been squeeking yet....about 1000 miles on them.....
no squeeks!!
axis ultimates front, axis metal masters in the rear....
:chill:
tsopranoMB said:
Thanks
no squeeks!!
:chill:
keep waiting Bro. enjoy the quiet for now, cause the squeek will come. I'll be switching ti the deluxe plus in the next couple of weeks. I'll also give a report on how they feel.
Thanks
DAMN.. I hear a very little squeak. However I think I didn't use enough disk brake quiet compounds. or I'm missing them somewhere.. Well, I'll go buy the stuff I usually use - disk brake quiet spray and redo the brakes again.. I think that is mainly the problem. Ill report back when I redo the disk brake quiet compound.
YellowIS5spd said:
Thanks
You are losing the brake pad squeak war my friend... :lol:
Penetration Specialist
Enevel12 said:
Wino_II said:
Good post. However, some pads will still squeek depending on how agressive they are. I did that same break in procedure on my Ultimates, still get the squeek cause of the type of pad. Switching to Deluxe + as soon as I can get a day off work.
really? hmm. I have the axis ultimates and never had a problem with any noise. Maybe because I did so many 140-20's :eek: 8)
Wino_II said:
how long have you had them on? mine didn't start out squeeking. but after about 3-4 months the squeeks started to come.
1 - 16 of 16 Posts
