I have my first autox coming up in a few weeks, and I was wondering whether or not I should leave my totally stock IS300 on between runs. I probably have about 15 minutes between each of the 4 runs. Please explain why as well.
I was thinking about leaving it on for a few minutes after each run, and turn it on a few minutes before each run, although a little more before the first run. A big concern of mine is making sure I remember to turn traction control off when I restart the car.
I think you should be okay if you turn off car if have to wait the 15 minutes. I do that.
After a run (and waiting in line) NEVER pull up your e-brakes. Let them cool down. If you do apply e-brake, you're brakes rotors may start to warp. During the entire day, I don't even apply the e-brake at all (evn while parked).
There's a mod somewhere that shows how to make "trac off" the default. I'm not sure if I saw it here or on LOC.
I leave it off. If I had a turbo, I may leave it on for a minute or so. As far as the e-brake do not use it at all. You may forget to release it and run with it on.
Mr. Negative
with 15 minutes I would definately turn it off. I usually crank it up about 1minute before I'll start unless they want you to line up early. I've only once left the Trac on and that was a horrible start and 1st turn before I got it turned off. I'm sure you'll do great. Have fun! :D
