1 - 10 of 10 Posts
Hey guys I just bought the Autometer shift light and I know the directions are pretty straight forward, but I was wondering if you guys can help me by telling me where I hook up the Green wire? As i'm not sure on this and dont want to screw anything up.
Here are the wiring instructions that it came with:
You need an MSD RPM activated switch. Then, you hook up the MSD to the car via the rpm wire in the ecu.
Then, the green wire you are talking about hooks up to an output of the MSD box.
In turn, when the car reachs a certain RPM, an output is sent to the green wire and you will get a shift light.
Woo hoo!
Woo hoo!
Sweet! .... how much ae those MSD switches?
Wait .... I just thought about something ..... cant I tap it directly to the ECU RPM wire? The shift light has the pills for the RPM that it should be activated at.
also what wire is the RPM wire on the IS ?
Oh, I didn't realize it was built in....
Here is the rpm wire that srt uses...seems to work fine.
http://www.mattssi.com/ecu.pdf
Can I have 1 dot?
Guru of Supercharged ISs
Not sure about that. I think you may be able to...that is were we tapped for the remote start. Try it!
yea I think you can ..... as I think thats where you tap for the Apexi RSM
yea I hook you up with some dots! how do it do it?
How do I donate Dots?
Click on the Profile button of the user to whom you want to donate Dots. You'll find a Donate button and an amount box. Enter the amount and press the Donate button. NOTE: Donating Dots decreases the amount Dots you have yourself.
Podiatrist
just go through the ecu.
OR spend a lot time time tracing wires.
1 - 10 of 10 Posts
