This is from a different thread, but I thought it needed to be pulled out under a more appropriate subject line.
The IS e-shift suffers from one way shifting, not having full control of the tranny. So issteve found this information out about a full auto tranny controller. Only drawback is a CEL -- but sholdn't affect anything else.
Anyone else have expereience with transmission controllers. Is this another thing that will take endless tuning to optimize, having full control over line pressures vs load and such is intimidating....
<<The check engine light coming on is an annoyance but does not affect vehicle behavior. Your speedometer, traction control, electronic throttle and general electronics will still function properly.
Our digital dash display is intended to work with aftermarket engine controllers as well as OBD-II compliant vehicles. So the answer here is, yes the digital dash is capable of working with the Haltech. Of the aftermarket engine controllers, the haltech will be one of the first systems the digitial dash will be able to display.
The PCS transmission controller offers two manual shifting modes that we have called "smart manual" and "true manual." True manual will select the gear you have chosen and will not shift until you have activated an upshift or downshift. This means that if you are driving along in 4th gear and come to a stoplight, you will have to remember to downshift 3 times to start out in 1st gear. Smart manual function is nearly identical to the Lexus IS 300 e-shift system where the transmission controller retains some control over shifting.
_________________
James Ballenger
Powertrain Control Solutions
_________________
James Ballenger
