1 - 1 of 1 Posts
for those people that converted from auto to manual i fornd this list on the forum. what else would i need minus tranny,flywheel & clutch thanks
IS300 Auto- Manual Swap Parts
BRAKE PEDAL & BRACKET
Description......................... Part # ....................... Qty.
Break Pedal Sub-Assy ....... 47106-53010............... 1
Break Pedal Pad................. 31321-53010............... 1
CONSOLE BOX & BRACKET
Description....................................... ........... Part #................................... Qty.
Shifting Hole Cover Sub-Assy...................... 58808-53020-c0...................... 1
Console Upper Panel Sub-Assy................... 58804-53011-c0...................... 1
CLUTCH PEDAL & FLEXIBLE HOSE
Description....................................... ............. Part #............................. Qty.
Clutch Pedal Sub-Assy.................................. 31301-53050 ......................1
Spring (For clutch pedal)............................... 90949-03119 ......................1
Cushion No. 1 .............................................. 90541-06036 ......................3
Bush (For clutch Pedal)................................. 90386-13015 ......................3
Nut (For clutch pedal stopper)...................... 94130-01001 ......................1
Bush (For clutch Pedal turnover) .................. 90389-06055 ......................1
Compression Spring ..................................... 90949-03111 ......................1
Clutch Pedal Pad .......................................... 31321-53010 ......................1
Clutch Pedal Shaft ........................................ 90101-10015 ......................1
Clutch Pedal Shaft Collar .............................. 90387-10003 ......................1
Clutch Pedal Spring Holder............................ 31353-35010 ......................1
Pin (for Clutch master cylinder push rod)...... 90240-08006 ......................1
Bush (for Clutch master cylinder push rod)... 90386-08036 ......................1
Clutch Master cylinder to flexible hose tube.. 31481-53060 ......................1
Clutch No.1 Hose .......................................... 90947-02c83 ......................1
Clutch Master cylinder to 2 way tube............. 31481-53051 ......................1
Clutch Release cylinder to flexible hose tube .31482-53030 ......................1
Flexible Hose Bracket .................................... 31484-53040 ......................1
Clutch Pedal Support Sub-Assy...................... 55107-53030 ......................1
CLUTCH MASTER CYLINDER
Description .................................................. .................. Part # ............................ Qty.
Clutch Master Cylinder Kit ............................................ 04311-12110...................... 1
Clutch Master Cylinder Reservoir Sub-Assy .................. 31402-22020...................... 1
Clutch Master Cylinder Assy.......................................... 31410-53020 ......................1
Clutch Reservoir Grommet........................................... .. 31417-35010 ......................1
Clutch Master Cylinder Reservoir Float.......................... 31426-22020 ......................1
Clutch Master Cylinder Reservoir Filler Cap Assy........... 47230-20040 ......................1
1 - 1 of 1 Posts
