Hi,
I recently had my radiator replaced and my mechanic noted that my 2003 IS300's old radiator didn't have the AT cooling section, instead it utilizes this heat exchanger on the engine block.
Is this an OEM solution, or did one of the previous owners install this for whatever reason?
Do you think it could be good enough? I've driven about 20k kilometers with it without issues, until yesterday.
Yesterday my IS stalled on me on a highway, giving me error code P0715 and not being able to carry on, so I had it towed. Obviously I will get the sensor and wiring this error code is about checked and/or replaced, but I can't help to wonder if perhaps this could be caused by the AT overheating? It was after a 2+ hours highway drive on stable 130-ish km/h.
Another possibility that I googled was related to fuel pump functionality. Do you think it is worth investigating as well? At the time it happened, I had over half tank left.
Also, I don't use the manual mode too often, but yesterday I tried it on a curvy road and noticed that the AT made a downshift when I didn't. Uphill, 80-ish km/h, 4th gear, full throttle, AT downshifted to 3rd but kept showing 4th, then at better revs shifted back up. Is that normal behavior? I haven't driven with manual mode enough to evaluate myself.
Currently, the car doesn't run at all, upon starting, it idles for several seconds and then the revs slowly drop until stall. Can faulty input speed sensor really cause this?
Thank you!
Thank you!
