1 - 9 of 9 Posts
@ the auto to manual guys,
my car runs fine with automatic ecu and manual transmission, except one thing:
When cruising on the autobahn, constant speed (for example 140 or 170kph) and holding this speed for a while (>10min), the car will suddenly slow down for 1-2 seconds. Its rather infrequent, but today it happend 3 times on a 1hour trip. It feels like hitting the rev-limiter, just a bit longer and harder. Or like the transmission gets "stuck" for a second.
Anyone else made that experience?
Maybe that is a function from the AT transmission control?
I can`t imagine, because the ECU input (AT indicator) is wired to Neutral permanently.
Podiatrist
The car is governed at around that speed 145mph or so.
You are probably hitting that.
Podiatrist
He said "140 or 170kph"
Ah. Misread on my part.
It's not a transmission issue. They don't get stuck.
My guess is the throttle body and ECU are doing something tricky. Possibly 02 sensor reading based.
Thx for your input,
Yeah, it happend in a speed range of ~80-110mph (140-170kph), constant rpm. Yesterday there was no problem at all driving the same route again (like every week).
First i thought there is an issue on the transmission vent valve (thought i did some damage when the transmission went in) but then i realized that is just an air vent. Perhaps both couldn`t cause a "stuck tranny" :lol:
I also guess it has to do something with the TB, or something like a fuel cut. But it kicks in very hard, so i don`t believe it`s just a faulty (engine) sensor.
If it is an electronical problem, it has to be something from the ECT part of the ECU, maybe because of some inputs which aren`t connected any more.
The car was running great when the AT was in, and 99% of the time it also does very well with the MT.
And seems like i`m not the only one having this trouble
any particular reason you didnt want to move to a manual ecu/harness?
Not really... The IS300 was never sold as a 5-speed manual on the european market ...so it is hard to get MT parts and they probably won`t be plug&play (there are also some wiring and electronic differences between Euro and US-models) ...but that wouldn`t be such a problem.
Just wanted to ask if somebody knows to fix the problem without changing the whole engine ECU :)
1 - 9 of 9 Posts
