Hi all, i've had my springs for about 1 month now, and havent had any problems with them. However, I have noticed that the front is noticeably lower than the reported 1 inch drop. I just wanted to check that the springs had been installed correctly. In the following picture:
The two springs with plastic sheaths are installed in the front, and the other two in the rears. Is this correct?
Thanks
do you have aftermarket struts? My H&R's are sitting in the lower setting on the strut droping it just alittle more.
if your springs are simular to s.techs:
back: the springs that seem to taper to a smaller diameter are the back, and are also taller.
front: the other ones
so yes, the springs with the plastic are the fronts, and the others go in the back.
No, stock shocks i have
Ok thanks
They're eibachs
