Does anyone here has them installed?? I just wondering what makes it $300-$400 difference except its fully aluminum contruction?? compare to the B6, they just look excatly the same to me.......
Why are you interested in getting the S6's? Very pricey but ultimately excellent quality. I think Wino_II or somebody got the B6's. You can compare the two since they are basically the same deal. Ones just lighter.
I heard S6 is almost 50% lighter than the B6(I could be wrong), since it has fully aluminum body and the 'Swift' spring. one thing i want to know is, how about the damper rate?? would it be stronger than the B6?? I got a pretty good deal on S6, that why I want to know more before i place the order since the Zeal's web site doesn't really say the difference btw them :crazy:
Weight is simply negligable though. I mean even if you gain 10 lbs, that is not rotational mass so the difference should make no difference at all. I don't know if the spring rate is the same. You might want to call Endless USA and ask them about it.
