Doing an oil change and noticed that there is a port without any kind of hose on it (see arrow). Anyone know what should be attached to this? I am the 3rd owner and this car has probably been monkeyed with, so I have found a lot that needed attention. Any help is appreciated. Thanks.
I recently had mine apart. It is a tube that is permanently attached to the timing cover. There should be a copy of that outlet on the other side as well. I remember looking at it and asking wtf it was but its obvious that it goes to nowhere when you have it apart.
Thanks. Did not know what thread to search for as I did not know what it was. Thanks for the replies.
Very convenient for running a vacuum/boost reference line across the engine to your compressor/wastegate/etc
Assuming it was used for same in the GTE setups...
