does anyone have a cam gear on their car and what degree did u set it to?
-5.7 like the dyno tuned on the forum? i just got mine put on and set it at -5 degrees seems good so far much better on the low end high end seems about the same. just curious if anyone else has one on and noticed a diff. i did get abit of weird churping sound sounds abit like valves but not 100% sure!
I have mine set on -3.0
how is it? mine feels different than stock for sure low end mostly mid range feels stronger but top end doesn't feel much different
i want to set it to 4 but it looks how to do it without taking it off again! whihc cam gear u got?
adjustable cam gears are adjustable with out taking it off. you just need to loosen the set screws and rotate the center section.
What exactly is a cam gear suppose to do for you? Why the different settings?
