I'm trying to put the Altezza grill in...do I have to take the bumper off?
98 Accord EX V6 coupe
AEM Intake, Comptech Headers, Random Tech high-flow cat, GReddy dual MX exhaust, BLTI Carbon Fiber Ignition cables, eibach springs, Axis wheels with Nittos, Wings West Spoiler.
15.1 @ 92 mph
2001 Lexus IS300 (Solar Yellow)
Coming soon: 12 second timeslips with the IS (my new all out drag car!)
Podiatrist
There are 5 screws that need to be removed.
There is the one metal center screw that holds the back of the grill. Unscrew it.
Next, there are 4 plastic screws. 2 on either side of the grill, attached to the bumper. Unscrew the screw until the center piece raises up. Then lift the whole screw up by the base. (Special screws by toyota)
Next, the bumper needs to be unclipped from the back. I believe there are 3 points where it is clipped in. Use a flashlight and you will see the clips on the bottom of the bumper.
Just slide those clips away from the grill, and push the grill towards the car and it should pop out.
Pretty simple. You would be able to figure it out without directions.
Hope this helps. I'm doing this from memory.
