tsopranoMB said:that is for a Supra 2JZ-GTE motor...not for an IS300
yup...different heads, etc etc etcDrDoS said:is there much of a differnce?
tsopranoMB said:yup...different heads, etc etc etc
read and search, this question has been asked many times over the past 5 years...
The flanges are different. Runners position are different.DrDoS said:could you be a lil more specfic or link me to a thread where it comeptly tell's me why?
only thing i could think is differnt is the VVT-i.
tsopranoMB said:sorry, you need to search on your own for that one...
bolt patterns on the heads are signifigantly different...
Toyomoto sells a tubular manifold for the IS300 specific motor
http://www.aturbolexus.com/manifold.htm
So could you buy the NA-T supra kits and then simply change the manifoldI S Stock said:you sir do not listen......if this manifold worked then we would be able to bolt up the many NA-T turbo kits available for the supra but it DOES NOT and searching will not kill you.
no because then the intake manifold wouldnt fit....without major modifications.....and then you would need standalone engine management...etc etc etc etcDrDoS said:now if you were to swap out the head with a TT head. now it would work would it not?
NA-T Manifolds DO WORK WITH THE IS, since N/A-T Supras USE THE 2JZ-GE MOTOR. 2JZ-GTEs cant be N/A-T, since they were never N/A to begin with.I S Stock said:you sir do not listen......if this manifold worked then we would be able to bolt up the many NA-T turbo kits available for the supra but it DOES NOT and searching will not kill you.
tsopranoMB said:no because then the intake manifold wouldnt fit....without major modifications.....and then you would need standalone engine management...etc etc etc etc
look at www.turboeast.com , IS300 specific
DrDoS said:thank you for the link.
IMPRIMIS said:All could have been found with a search there are more IS300 specific kits
DrDoS said:yes i know you are righte. and please excuse my lazizenes and noobism for searching. but i am trying to peice together a cuztom turbo kit built for responce rather then crazy power. And trying to keep it cost effecent. The ones on the web are very expensive. And i think i could get away cheaper if i were to peice it together my self.
IMPRIMIS said:good luck :lol:
