1 - 2 of 2 Posts
I have yet to see an actual Altezza guage, but I've seen post referring to this cluster. The posts refer to the Altezza having the RPM guage where it should be. Does this mean the larger of the guages on an Altezza is the RPM gauge? On the Altezza gauge, is the speedometer switched with the tachometer?
How much work is involved swapping out the IS300 gauge cluster with the Altezza, if its even possible?
You F/I guys, have you tried or is it possible?
There are two styles. One of them has everything in the same place except the subdials are moved around and the MPG is replaced by the fuel pressure gauge instead. There is also another version that has the speedometer on the left side and the tachometer in the middle. There is also a bezel around the 3 subdials on that version. Let me know if you come across the latter one in black or blue because i'm looking for one.
1 - 2 of 2 Posts
