what companies makes good altenators?and what are the price range?
i got an hr between classes and i dont want to be bored or drive around for an hour,so im planning on upgrading the alternator so i can hook up a PS2 and play for a hour and not burn out the alternator :D
:lol:
What you need is a battery, not alternator. :roll:
Try Optima Yellow Top.
vlad_a said:
:lol:
i was told if i use the electronics(like stereo) for a long time non stop,it's bad for the alternator thats why i asked this question.as u can tell i dont know anything about this stuff :crazy:
When the car is turned off, alternator is not in use. The battery is what powers up the equipment. I think you will be OK using stock battery for an hour. Try it. If you see it running low (dimmed lights or voltage gauge has gone down), that means it is time to recharge.
Optima Yellow Top is a good replacement for the stock battery, designed to withstand long discharge.
