Anyone Know Of Any Is300's Running Alcohol/ethanol?
I Am Considering Converting Mine... Would Like To Know What All It Would Take...
1yellowturbois said:I am running the stage 2 boost cooler unit... It is a great setup with some of the following features...
Pump is compatible with all mixes, Unlike aquamist
Pump can be run dry
Low level indicator
Power on indicator
Progressive controller that adds more alcohol/water as the boost pressure increases
downsides...
progressive controllers maximum setting to start injection is 8psi, so you are burning the mix when its not neccessary
If you drive like I do, the tank goes empty relatively quick (1tank gas or 1 1/2 tanks)
car will need to be tuned with the setup
I gained approximately 28whp with this setup, simply because it enabled me to turn up the boost higher than I could safely run on 93 alone
