New IS300 owner here! Finally bought my 6th grade dream car.
Looking for wheel specs and suspension without fender modifications! Preferably wheels that are 17-18inch that could possibly fit the LS400 brakes in the future?? Gong for a track/beefy look, please post some pictures below. I'll drop a picture of my newly purchased IS300 below! Thank you.
Welcome and congrats for the buy. Looks like most of us have that in common, it is a long love story with the IS
If you're really looking to track the car keep the rims at 17" or smaller. More tire is better.
I have MOTEGI Racing MR119 18" x 8" with ichiba wheel spacers (+15mm Front / +25mm Rear).
- Fortune Auto Coilovers with Swift Spring Upgrade
- Figs Front End Refresh Kit
- Figs Rear Lower Control Arms
- Stock Rear Uppers
- Eibach Upgraded Sways on Front and Rear
- Cusco Front Upper Strut Tower
- BRZ Swapped 4.0LSD
- Currently wrapped in Michelin A/S Pilot Sport (Great tire but expensive - probably next round will do a slight stretch on some summer slicks. As I always want to go a touch lower)
- No Fender Mods other than a very very slight interior roll to reduce the sharp edges. - not noticeable from the outside.
The only pain I have is Traction Control Always kicks on because of the unsprung weight of the wheel spacers in the rear so I always just dis-engage it.
I chose TSW Nurburgring wheels because they're "rotary forged", which isn't quite as awesome as a real forged wheel, but is way way cheaper. And a LOT lighter/stronger than a standard cast wheel. Mine are 18x8.5 (+45, but I have 3mm wheel spacers making the wheel actually a +42) up front, and 18x9 (+63, but I have 5mm wheel spacers so +58 actual) out back. Rubber is Michelin Pilot Super Sport. 245-35 front and 265-35 back.
Car is lowered on Eibach "pro kit"and Bilsteins. Fenders rolled a little, but nothing major. This wheel/tire combo doesn't rub, and doesn't poke out so you don't really notice the car has big rubber on it until you look closely - which was exactly what I was going for... These wheels EASILY clear the IS350 brakes (what I've got), but they will also clear the LS400 brakes, too.
I chose TSW Nurburgring wheels because they're "rotary forged", which isn't quite as awesome as a real forged wheel, but is way way cheaper. And a LOT lighter/stronger than a standard cast wheel. Mine are 18x8.5 (+45, but I have 3mm wheel spacers making the wheel actually a +42) up front, and 18x9 (+63, but I have 10mm wheel spacers so +53 actual) out back. Rubber is Michelin Pilot Super Sport. 245-35 front and 265-35 back.
Wow this looks almost to what's in my head. Love the no lip look. I went on offerup and found the TSW rims, asking him what his specs are because they look squared to me.
https://offerup.com/item/detail/585073979/
I don't mind it being squared though. How do the Pro Kits run compared to stock on stock shocks? B4,6,8 on yours?
I have the Pro Kit and Bisteins with TRD sways. Car rides smooth and even with SuperPro bushings throughout, I wouldn't call it harsh at all. However, the car is a bit "bouncy" on roads with undulations... Between my workshop and home, I drive a stretch of road about 2 miles @ 60-70mph. In the right lane, there are small dips every second or two, and it's a bit annoying. If you drive 45 or 85 over this section it's ok, but between 55 and 75 it's just not good.
For reference, I'm 38, and not a kid anymore. What used to be acceptable NVH when I was 20 is not ok anymore!
I think lowering on stock shocks is a bad call. In fact, hard to imagine stock shocks being a "good call" on any 15-20 year old car, regardless of springs!
